Moto Metal 962 33"
Gzes
the drifting 2dr
Wichita tx
Yea anything over 18s are fugly. Unless your rockin a 20 on 40s
andrewlee
Mine rub in front. Rear not at all. Ill try get pics for u. I just got out hospital.
note2
D
da318state
Oh dont worry andrewlee i just went and took at a look at some of your threads and i like the rims/tires you got on dat hoe. Does it rub bad? And if you dont mind me asking do you know how wide your wheelwell is? Because on my 00 yukon denali i think my wheelwell is 34-35" at its widest.
D
da318state
ok i just finished doing some measuring on the 00 yukon denali and i've figured that with the 1.5" block in the back they will fit just fine in the rear. Also with the 2" T-bar crank they will fit in the front, but the only thing i'm worried about is if they will rub any of the parts/fender in the front, does anybody have and suggestions.
Matt06Yukon
Your gonna have to trim upfront. The back will probably be fine. You'll have to trim the lower airdam, the plastic piece thats attached to the bumper. You also might have to trim the inner fender well infront of the front tire.
D
da318state
ok, thanks. ill post pics soon as they get here sometime in the next 2weeks.
D
da318state
ok, thanks...do you have any rub on any of the mechanical parts inside the wheelwell?
carloogbuyNuh
