Moving the Denali with out front diff
6speedblazer
Just heads up I this purchase Denali a couple months ago dove fine on the test drive around city speeds.
Up on the Hwy driving it home starting at 65 MPH it started to rumble and howl I thought get front diff you could fell the floor vibrate once you got under 60 it was fine.
But at 70 MPH it was bad when you foot was on the gas, It went away foot off the gas.
It end up being a broken Carrier bearing adjustment tab that let the Preload on the Carrier bearing go to Zero it back off the Adjusters.
I already purchased New R&P and Bearing set Ect so I changed everything out.
I might of gotten away with new Bearings and replacing the Broken adjuster tab only But I already had the gear set so might as well do it all.
It cost me $400.00 in parts and 20 Hours in labor of anyone else has a howling front diff for any other DIY.
i rebuilt mine a few months ago for the exact same reason. i got away with new bearings and seals. i had the most time in cleaning it at the parts washer.
Ftherrian
