MTX ThunderForm Chevy Tahoe 2007-2010 Custom Sub Box
shundal
NorCal
Good to know you were able to fixed! Yea the console sub is a great solution for adding good clean bass up front and giving up zero space.
wheatswake
houston texas
the box with the mtx amp already installed sounds good to me, its also nice not have to do an amp install somewhere else.
aggressive
How is everyone securing these to the floor? The instructions say to use a 2 inch screw but that sounds a little sketchy to me...
Keanen55
Keanen55
HOUSTON, TX
I didn't even bother bolting it down. The center console holds in place just fine! :thumbsup:
aggressive
Thanks for the info. I just finished the install with a 600w Comp RT. Sounds amazing!
Shimmy23
WA
Based on the quick read, no one secured this to the floor? Aren't you worried it will somewhat move and eventually start to vibrate/rattle the center console?
Chris9117
I have a 2011 Yukon Denali. Not sure how similar this would be to a 2011.
Question, did you have to take the seats out to install this box? Where did you put your amp for this box? How long did it take you to install this box? This is very good information that was discussed on this board and I will using this to install. thanks
M0rph3us
I found this guy on eBay that sells a complete kit for the center console install. Has anyone used his boxes before? Seems very reasonable considering it comes with the wiring and amp that all fit nicely under the console.
Link here to eBay auction
Moue
