Multifunctional switch washer functions swap
deathfry
Is it possible to make front washer work by pressing side button and rear by moving the "wheel" on the switch?
Bigburb3500
You want to swap functionality of the switches?
If I understood that correctly, you probably could just change the tubes feeding the sprayers. That way when you engage the rotating switch it pumps the read sprayer and the buttons sprays the front. Only issue is you will lose the auto wipe function.
D
deathfry
And the rear wiper will work while spraying the front window?
Bigburb3500
Yes. Thats probably the “easiest” way to flip the utility of the switches. The next step if you want it to operate 100% correctly will likely be to hunt down a wiring diagram and require the stock to engage as you want. Seems like a lot of work tho
D
deathfry
Exactly! So I wonder if anyone tried to do something similar
mikez71
So no more variable speed windshield wipers? Or are you willing to add a separate speed switch?
sticksboss
