Multimeter Preference
Fless
Super Moderator
Elev 5,280
Fluke makes great products. Call me old school and laugh all you want, but I use a 35-year-old Simpson 260xlm, owned since new. The analog meter is awesome for checking variable resistors for dead spots, and it's big enough NOT to fit in a typical hand. For digital accuracy I find that a cheap Hazard Fraught one works fine.
About a year ago I mistakenly smoked the Simpson and had to send it in for repair. Turns out the service center was about 30 miles away from where I went to high school in NC Illinois. Anyway, for a flat rate they repaired it, put a new mirrored meter movement in it, and calibrated it.
That’s the one I learned electronics on. That and an old Tektronix oscilloscope with a vacuum display.
I am about to trouble shoot some cab roof marker lights that do not work, and I was wondering if you folks could recommend any multimeters. The last one I had -- years ago -- bravely sacrificed itself to an over god to let us know we had failed to depower the circuit. :-(
Thanks!
For cab roof marker lights, you could use any dirt cheap DVOM or even test light. If you were testing current draw or high, life-threatening voltages (110VAC house power included) and needed utmost accuracy, then I'll add my vote for a FLUKE to the list. I have Cen-Tech DVOMs all around the house since I got them free with other purchases at Harbor Freight and they're perfectly fine for testing batteries or for continuity. I have a few $20-$40 ones from the big box stores and Radio Shack around the garage and shop that serve my needs just fine. For any automotive use, especially cab lights, a $20 DVOM would be plenty over-equipped for your needs.
Wow! Looks just like my first multimeter, which I got used from someone, back in the 60's. It was great for working on electronic assemblies, particularly the very sensitive Ohm resistance scale, as before semi-conductor technology was introduced, precise resistance measurements were much more critical in maintaining oscillator circuits, as well as other circuits.
Hobbitsam
