Multiple Cylinder Misfire
vanilla_gorilla312
I've got a problem with my 1997 hoe. When I accelerate anymore than under normal driving conditions, i.e. passing a slower car, or accelerating onto the freeway, my hoe starts to tremble and sounds like its missing, and the check engine light comes on and starts flashing. I first pulled up the "Too Lean left bank O2 sensor" code, so I changed both left bank O2 sensors (Bosch) and it still did it. This time I got a "Multiple Cylinder Misfire code" so I decided it was time for a tune up anyway. I replaced the Distributor Cap and Rotor (Duralast Gold), Bosch +4 Fusion Sparkplugs, Bosch Sparkplug wires, changed the oil (Royal Purple) and filter (K&N) and replaced the fuel filter. It still does it. Do I need to change the right bank O2 sensors too just to be safe? Any ideas
992door
Greenville, NC
run some seafom in your gas. maybe you got some trash in one of your injectors. No i would not change the other ones no point if it is not on that side.
BOSS
The People's A D M I N
Dallas
Check all vac hoses, connections, inj harness, spark plugs.
And read JK's 6.0 thread. You'll be pulling the cats out of the exhaust loop to test I bet :waytogo: Just test and test twice, we missed it the first time somehow.
Ok ok I'm guilty. I didn't read your entire post....sounds like clogged cats to me. Still, read JK's 6.0 swap thread.
B
JKmotorsports
Austin, TX
There are several things will cause the pcm to set those particular DTCs, but the most common causes for multiple misfire and lean bank DTCs is a fuel delivery issue, leaking intake gasket, or a clogged cat.
99Yukon_Z71
Crazy Puerto Rican
Humble, TX
Run the seafoam like they said, but I bet that if that does not work, you will be replacing the CPI Spider system. It is a fairly common problem in our 1996-2000 trucks. I have done over alot of these!!! Let us know....
knotty
here is what was wrong with mine .......i replaced 5 out of my 8 injuctors and still ran like crap so i took it back to the shop and found out it was a faulty cap , it has never ran this good since i have owned it !!!! its crazy i just pelaced the cap 1 month prior but i guess now i know that you can buy new parts that are bad only cost me 200 to figure it out but im back on the road ! YAY ME
vanilla_gorilla312
vanilla_gorilla312
I have bought a faulty cap once on my 1989 Chevy 1500 pick up. I will try the seafoam first and go from there, cheapest to most expensive of course. Thanks for all the ideas. :wtf2:
hapyspaz
Austin
Yeah, your lean O2 codes are because of the misfire, very often O2 codes pop up and very rarely is the a problem with the O2's.
As 99Yuk stated, you are more than likely looking at a bad fuel pressure regulator. Unfortunately it is mounted inside the upper intake manifold with the "injectors"
Try the seafoam, but this may be where you end up.
vanilla_gorilla312
vanilla_gorilla312
well I tried the seafoam but with no improvement in my problem. I am going to look into the fuel regulator and catalytic converters. Thanks for all your help. Will keep you posted on the progress
GMgarbage
