my 2004 Z71 journal
H
HACK BLOCK
NYC
I was surprised too. after I changed it I noticed it went away and never came back so I assumed it was from that
H
HACK BLOCK
NYC
tried fixing the door lock today and the cylinder lock on the door keep coming unhooked from the mechanism. I also noticed I have a wire harness with 3 plugs but only 2 spots to plug into.
Isn't there like a push on clip that slides over the lock cylinder from inside the door?
H
HACK BLOCK
NYC
I fix the cylinder lock but what seems to be the problem now is the the actuator. it's loose and not attached to the door or latch so I think I might need a new actuator and latch
H
HACK BLOCK
NYC
changed the oil today and decided to check the oil in the front dif and it was about half a qt low
H
HACK BLOCK
NYC
tried to figure out my door lock issues and found my actuator to be broken in about 4 pieces and barely holding on to the latch. I glued what I can together and got it to be serviceable. using the key I'm able to lock and unlock the doors. using the fob or the switch I'm able to unlock but it will not lock the door.
H
HACK BLOCK
NYC
I installed led interior lights and I noticed the middle of the 3 dome lights are brighter than the other 2 with the buttons. is that how it's supposed to be? the front map lights do the same
H
HACK BLOCK
NYC
just an update what i got done so far
after months of looking I finally bought a tahoe, 2004 Z71 with 110k. not in the color I wanted but it was only $2500. after a couple days of driving I've noticed a bunch of small things about it. because this is my first ever GM vehicle I have tons of dumb questions and concerns. so any help would be much appreciated.
has a check engine light on for p0171 and p0174 and abs light that only comes. on when the truck is moving
ended up being the evap purge valve
cluster speedo sometimes works and oil doesn't work at all. 1 led appears to be out and PRND321 is dim.
changed all the motors but had 6 bulbs out and didnt bother fixing it
the radio makes a noise like if I'm inserting a cd and it's trying to read it. this happens every time I start the car and it happens for about 20 seconds. also the little cd light is blinking all the time
had to remove the radio and take off the top cover to remove 2 stuck CD's
when I turn on the rear air, it makes a loud noise like if the fan it no good. still didnt check this out yet
the parking brake doesn't do a dam thing. it has no resistance when stepped on and I have to pull it up by hand.
cable is broken, still trying to find the right part number for it
steering wheel make a noise like if something is broken when fully locked, has about a 2-3 inches of play in it, only the right hand buttons work and none light up. i think my clock spring is bad but dont know how to test/check
has hard start problems after adding gas. changed the evap purge valve
the driver side door is sagging. it looks like the hinges are loose. I have to lift the door to close it. doesn't lock with the remote or using the switch on the door. heated seats works when it wants and only the back gets hot. changed the door pins. door only unlocks with the remote and always have the door ajar message on so no heated seats
gas cover is loose and swings open whenever it wants. ended up putting velcro and a locking gas cap.
other than those things I noticed I'm. still gonna change all the fluids and plugs/wires and filters ect. I plan on keeping this truck till the wheels fall off. it will be primarily a family vehicle for probably the next 3-6 months then will be my work truck
CT_85
