My 2008 Esky Project, Pic attached
91RS
GA
What a deal. I tried to find a “mechanic’s special” and the money they wanted for all of them would have made it more expensive than buying one that wasn’t broken.
Your problem is very likely lifter failure (the hydraulic lifters don’t fail in the same way the AFM lifters do so it isn’t easy to spot visually). My guess is your compression will be fine. Do a running compression test and I bet you’ll have a result.
73TA
91 RS, thanks for info. What do you mean by a "running" compression test. I assume that I would actually start it up and check it will it is running?
Mike
DevilDog0621
