My 2011 Escalade Build Thread!!
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
So like the kit I ordered(3/5 drop). I dont have to cut dead coils to get lower,because the 4305's are right where I need to be. The TB springs must of been in the older kits you offered which required you to cut the dead coils if you had a lot of bounce or wanted to g lower?
no the tb springs are in my 5 inch rear kit. If people want to go liek 6 inches then i have them cut the dead coils but on the 5305 springs. Totally different.
Here is a picture of the 5305 tall one vs the tb coils
Yuko04
"SquareBODluvr"
MN
AHHHHH I see. Oh some I'm good. When I pulled them out the box I was like um, I wont be cutting any coils off of these. Cant wait to see the esky!!
ihaveamustang
Atlanta
2wd im guessing also makes the swap of the front spindles very easy...im assuming 4wd you would have to press the half shafts out?
Have yet to look at the front suspension on this truck, and yet this is my first 4wd vehicle
No press out - the hub bolt holds everything together. One pain in the ass I ran into was having to cut the upper ball joint stud off right at the nut to keep it from rubbing on the boot. There is absolutely no stud left beyond the nut.
Not overly difficult, but I was surprised I had to chop that much.
Preludepearl417
Nice Thread! You have the same idea i do for the Esky. Now i know what i need. Thanks.
THE YETI
Director of Operations
South FL
Actually no they changed the rear disks end of last year. 14.5 now the older versions were 14.25
Hey Tony.. just curious, where does Wilwood state this, or maybe you have a newer part number? There website still shows 14.25"? Not like .25" is gonna matter to me, but at the same time, I would have liked to have had bigger for the same price I paid for the smaller ones. Did they also reconfigure the bracket as well to move the caliper off the rotor to get full pad contact?
This is going to cause a huge problem for me when I go to swap out my rear rotors when the 14.25" need to be changed. I'd rather address it with Wilwood now before it gets too long. I've only had them for about 9 months now. Thanks!
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
i had them custom made and fits fine with stock set up :) actaully found out a friend of my buddy at djm worked there and so i had a favor called in. One off yeah baby!!
also getting longer arp bolts for rear 2 piece hats so goes thru completly. one thing i didnt like from the kit ist hat the rear bolts are only 3/4 inch long leaving threads exposed. like the front I want full contact on the threads that hold the hat to the disk.
Im hoping to get the parts soon and then i can take full pics. im going to try to get the lower del sphere arms in this week.
THE YETI
South FL
ah, ok, i must have misunderstood. Your first post indicated that Wilwood had switched to a 14.5" rotor at the end of last year and I thought that meant they all came like that now, didn't realize it was for custom orders only.
Thanks for clearing that up..
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
im just pulling your guys chain its 14.25 but i liked rubbing 14.5 to black bear lol.
Administrator
Ziiiiing
