My 2022 Tahoe Bose Audio Mods
Max2013
Like many of you, when I get a new car/truck I am compelled to do something to it. So I researched this forum and found all the threads on upgrading the Bose Audio system. Some people found the factory Bose system to be lacking at the subwoofer level. I found the bass to be marginal, not bad on some songs, and not enough on others. What I really found to be missing was the high frequencies, you know, the sizzling of the cymbals and the crisp clicks on the hi-hats. That might just be because I have a loss of high frequency hearing caused by a Fender Dual-Showman back in the 60’s. Before I get cranked up, let me thank JohnnyFamous, Sinewave, and all of the other forum members that provided so much needed information about their mods and installation.​
To make all of this easier to digest, I am going to divide my activities into a few parts (posts)…..PART-1 Speaker Wiring. I picked up the PAC Audio Speaker Connection Harness Kit APH-GM02. Now, as you know, getting to the Bose amp, in the 2021/2022 models is kind of rough on an old man like me. I only intended to do it once, so I extended the length of the Pac connector leads, as you can see in the photos. That allowed me to fiddle with the wiring thru the rectangle fuse box opening in the rear. As others have done, I ran a test frequency to all speakers to make sure that I knew what was what. I also measured the DC resistance of the speakers. FYI, h
ere are some photos and diagrams
M
Max2013
Part-2 Replaced Front Center Speaker with a tweeter. I used the BZRK Audio SST-160 Titanium Bullet Super Tweeter and mounted it on an old front center speaker frame. That tweeter really improved the high frequency response for me. It would be really easy for you to make your own bracket for this tweeter. I just happened to have an old speaker so I used the frame and the factory connector.
M
Max2013
Part-3 Added a Small Amp. After some trial & error and other experiments, I added a 2-channel 40 watt amp (JVC KS-AX202) and connected it to two 6”inch subs. I used the factory subwoofer speaker output (there is only one output, no left & right) and connected it (in parallel) to the speaker level (high) inputs of the amp. I bridged the amp outputs and wound up with a single sixty watt subwoofer output to my two 6”inch subs, wired in parallel for a 2 ohm load. One might ask, why use six inch subs. And the answer is, because I had a pair in my spare parts closet for the last four or five years. Why not give ‘em a shot? Now, if I had not already had those 6” subs, I would have gone with an 8” or 10”subwoofer(s). My end goal was to put the box between the passenger seats and not in the cargo area
M
Max2013
Part-4 Power Supply. I bought a package of 40A Mcase fuses and used one to make a connector to access the rear fuse block. I used the empty fuse F21 Position to provide power. The F21 empty fuse slot was made for a 40A fuse so I felt comfortable tying in at that point for power. I added an in-line fuse holder and I am currently using a 10A fuse in it to power my small amp.​
My small amp, needed a 12VDC, hot-only-with-ignition-on, connection, for the remote (turn on and off the amp) function. I could not find one in X1, X2, or X3 connectors. While snooping around under the Tahoe right hand side quarter panel, I popped of a connector, near the rear, and checked it with the volt meter. I do not what the connector fed, but there was a BROWN wire that was dead, with the ignition off, and it was HOT, with the ignition ON. I tied into it and ran my wire almost straight up and into the right rear side panel, and then under the almost useless tool tray, and onto and into the left side panel where my amp was to be located.​
I mounted the amp, on a board using 1” plastic standoffs to provide an air space between the amp and the wood. The board & amp are tucked in the rear panel where a factory Subwoofer could/would have been for some other GM models. I added a few mounting screws to keep everything in place. The 8”X 8”X20” sub box sets in the floorboard between the rear passenger seats. It is tied down so it can’t slide around.
Good detailed write-up, so far. I hope that you achieve what you desire.
Runninstuff
Great write up. Won't you need a ANC bypass like they sell on lljcustoms.com? Could you have used a fuse tap for the 12V switched power?
M
Max2013
Not sure mine has the ANC. I have not experienced any unusual noise/sounds from the audio system while on the road. BTW, some folks, on our forum, have not spoken well of the customer service from that particular vendor. I did not find any 12V switched power in the rear fuse box. I could have missed it.
M
Max2013
I've read a little about the factory sub channel lowering power as volume increases. Have you measured for this "feature?"
I have read the same material that you reference. I tried to "listen" for that effect. If it did lower the bass volume, I really couldn't detect it. I might drag my o'scope out there one day and see what I can see.
marktorres4242
