My daughter had my Tahoe and she left it at a so called friends house as she went out for her birthday. Well they tore up the column, took it apart and took the ignition key control module (after busting the cylinder), damaged all 3 door locks. The inner door panel was bent on the drivers side. They stole the Hi-Lift Jack that was mounted on the Yakima Megawarrior (They bent just about every bar on it, I will try to straiten it and reuse it). They stole the wheel lock key and the spline key too. So have to play and try to get the locks off to check out the rear end which is clunking like some of the teeth are broken on the ring/pinion. They broke the bowtie on the nose of the truck even. Both Alpine amps are gone along with the Bazooka Tube. So I will be having a few trips to the Wrecking Yard to try and find parts to repair. Until then does anyone have a extra ignition cylinder and door lock cylinders (with or without keys) they can part with so I can try and secure her until it cools of here in AZ (108deg at the yards isn't fun)?
Sorry, Had to vent!
Sorry, Had to vent!
