My Air Ride Build Log
S
shundal
NorCal
yates [emoji769 said:
;910599]You know you can buy just the tanks and brackets, they're setup for dual 400C compressors. The kit is discontinued but I can still get those made if you would like.
I'm looking to see how much it will be to send back my my 380 and replace them with 400's. If I go that route I'll get a price from you. Thanks.
S
shundal
NorCal
Accuair e level with rocker switch just showed up. Time to start planning the layout.
The quality of the parts and harnesses are excellent.
S
shundal
NorCal
Double checking that the Bilstein HDs fit over the bags properly. Everything fits perfect. I just need to measure out the correct metal sleeve to cut and weld to the bottom bracket.
---------- Post added at 11:16 AM ---------- Previous post was at 11:10 AM ----------
Shot of the rocker switch, which will be mounted in center console coin holder. This will allow it to be hidden and unseen unless needed.
djscrubb
Nice I'm just waiting on my compressor doing the exact same setup only using paddle valves
---------- Post added at 12:51 AM ---------- Previous post was at 12:50 AM ----------
I talked to uas and they said that gunna need 180 psi in front to air up its crappy cause only need like 60 in rear
---------- Post added at 12:53 AM ---------- Previous post was at 12:51 AM ----------
I'm very curious how these uas bags will be required to be hight wise on the shock if you were just sticking with the stock position on the shock
Nosho47
180 psi is a lot for the front. I have the KP front bag brackets with slam specialties bags up front and fully lock out the front at 150 psi. My ride height is at 125 psi. The problem I have now is that the ride is bouncy without shocks. I'll have to find a way to to mount my shocks up front
Sent from my XT1254 using Tapatalk
S
shundal
NorCal
After talking with Nosho47, it looks like the arnott rear bags have a slightly larger diameter than OEM. This makes the bag get way to close to where the bump stop bracket is cut. I will be sending my Arnotts back and ordering the oems.
Nosho47
Here is the difference between the arnott and OEM bags side by side. At first I didn't think they were any different.
mitchellowen
