My Air Ride Build Log
NASTY GM
Nor Cal
Keep it up!
I'm running 2800 lbs Conitech rear bags and they give a lot of lift.
Nosho47
Keep it up!
How much is psi is your ride height in the rear? What setup do you have up front?
Sent from my XT1254 using Tapatalk
S
shundal
NorCal
I'm going to get back to this on the weekend. Had a family death to deal with, which has put my law practice behind. Playing catchup at work before this gets started again. Everything is just sitting in the garage for now ready to bolt in.
S
shundal
NorCal
Thank you. Finally checked the mail after a few days and the last fittings I needed came in. These are 5/32 PTC to 1/4" NPT fittings for the rear air bags to work. Then a female 1/4" NPT to 3/8" PTC fitting goes on the other side to the accuair manifold.
Lilmule
