My cruise won't work
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Testing and Inspection
170617472
Cruise Control System Check
Symptom Related Diagnostic Procedures
170617178
Cruise Control Inoperative (Gasoline) (Part 1 Of 3)
189366626
Cruise Control Inoperative (Gasoline) (Part 2 Of 3)
189366627
Cruise Control Inoperative (Gasoline) (Part 3 Of 3)
T
Trexter67
Never mind, I do have a wiring problem
---------- Post added at 09:26 PM ---------- Previous post was at 09:00 PM ----------
I'm getting a little confused, could you please tell me what wire is what color. I'm getting confused at step 8, what color is the cruise release, what color is the brake circuit, and what color is the cruise engaged output?
SunlitComet
OBS Jedi-Do Good
for simplicity (if possible) brake should be white should be the white wire. release should be the purple. and the light blue/black wire signals the pcm that the cruise control is active as the pcm uses the info to effect change on transmission shifting.
T
Trexter67
Sweet, thanks, I will test it all again tomorrow and ill post what happens
dacpdx
