My latest Adventure, update 7/11/21
bigdog9191999
bigdog9191999
sw michigan
Alright, more pics!
Light!
Low beam
High beam
The high beam is both brighter and decidedly above the low. But also when the high is on the low is also . There is now way to have high with no low. Which is fine..
Also got.rhe unoints swapped in the Tahoe. Looked like originals on the front end. Not bad for 235k and only one joint was actually dry and causing a little vibration.
bigdog9191999
bigdog9191999
sw michigan
This is for the light. These are the 7" version, and I only see the 10" as the smallest currently. They came from china, and took little over a month to actually show up. I could have done a refund weeks ago, but I stuck it out as I was really excited to see them and give them a try. Something that can act as a fog/driving light as well as extra longer range. ( Have yet to see how they do in either capacity in real world).
I intend to hook them up with the "low" directly in place of the fog lights and use the stock switch, the "high" I intend to trigger with the actual high beams through a relay as an "aux high" type setup
https://www.amazon.com/dp/B07V7D3H6...abc_ETKYA4PW8ZN1VEM2VXZE?_encoding=UTF8&psc=1
bigdog9191999
bigdog9191999
sw michigan
Ok so a little don't the other day, not as much as I would have liked for the weekend. But that's how it goes.
I swapped in some new black housings in the burb, and when I did I did the 4on high, as well as drl delete, in favor of turning that spot into park/turn so all 4 bulbs do the same on the front now. Same method as used earlier I this thread
Currently all three trucks are set up this way, although I did add a secondary drl to the Denali ( covered earlier in this thread) I have yet to swap the led bulbs in the Denali yet, but with the results I got from the burb I can't wait. The Tahoe will remain standard as it is the cheap beater
IMG_20210423_131251164_HDR.jpgIMG_20210423_131257757.jpgIMG_20210423_145402592_HDR.jpgIMG_20210423_145728602_HDR.jpg
Sent from my moto g(6) using Tapatalk
bigdog9191999
bigdog9191999
sw michigan
Also got the pickup I bought almost solely to trade for a grand marque soon. I will be making the 300 mile round trip on wed afternoon.
And the car trading for
Also a couple shots I got with the gooder camera whole playing with it the other night of my very dirty car.
bigdog9191999
bigdog9191999
sw michigan
ok more content just because!
i grabbed some 17'' wheels the other day in prep for some different tires to go on the hoe.
they are some 315's off this tahoe, as he is getting new ones.
bigdog9191999
bigdog9191999
sw michigan
another something i did the other day because i keep having issues when i hook to the trailers, so i tried something to eliminate the issue, as well as added some extra help.
Hugh Wilde
