My latest Adventure, update 7/11/21
bigdog9191999
bigdog9191999
sw michigan
Well not a crazy amount to update really, but I did do one more silly thing for the house stereo equipment.
We grabbed a pair of towers that are direct little brothers to the ones we have ( which means they will very closely match acoustically to the current ones. ) And the new center that was with them is also much closer . In fact all 5 speakers will have the exact same diaphragm in them ( like the ones I installed in our current towers, ) they just are slightly different crossovers in the towers. The plan is to use these towers as our rear channel speakers.
Our current towers along with the new Toni's towers
Unfortunately they are not without fault and need some repairs. The tweeters in the horns are both dead, and one sub has a crack. After I got them home I pulled a tweeter from our speakers and tested each in each tower to verify it was the tweeter diaphragms or the crossovers or both that needed repair. Thankfully it seems just them. ( Will find out in a couple days when replacements come in)
Also a larger center speaker that will be a closer match to the rest ( same tweeter diaphragm)
All the parts will be showing up in the next day or two for repairs.
Also got some repair done to the Saturn as the blower quit working. It appeared after replacing the motor and resistor that the motor pulled enough power to blow the fuse. Direct tested the old blower ( that appeared to be a junk yard replacement) it didn't work at all.
bigdog9191999
bigdog9191999
sw michigan
Also our little boy turned one on 1/2/22!
Here are a couple pics . One is from shortly after we got home at 3mos and now. My has he grown, and has over a year of growing yet to do! He is about 11lbs currently, and should be about 22lbs when fully grown.
A couple breeds off. He is NFC. (Norwegian forest cat). Which is ancestor to the main **** ( is the older of the two breeds, MC is descendants of NFC)
I should have known from the eyes. Ragdolls are blue. Fur looks exactly like my boy’s did. Beautiful cat.
dda1
