My New Look: A complete exterior makeover
SC88
SC88
Chicago Burbs
I hope this works, i'll snap some better pics when I get home.
Thats a 2/3? Do you have any issues with rubbing with 26's? I am running a 305/30/26 and don't want to cut up the truck just to fit a set of wheels or lower it. I have a small issue with rubbing on the plastic at times when reversing
lyukonr
los lunas, new mexico
Yeah its the jdm 2/3 kit from Tony... I did a little cutting on the plastics, but its not necessary. It only rubbed a little when reversing like yours.
SC88
SC88
Chicago Burbs
Oh so thats keys in the front? well maybe if I get a drop (Spindles) it wont go that low. Yours looks like the 3-5 kits I've seen. Looks good though!
fire730
Louisiana
Lyukonr's sig sys he has 295s but you have 305s right? So that will make a difference as far as rubbing.
SC88
SC88
Chicago Burbs
Not by much, His your OD is 32.96 and mine is 33.20 so I don't think that would be much of a issue. The rims look to be the same too so I can speculate the width and offset being the same.
Do you have pictures of how much the plastic was trimmed?
lyukonr
uploadfromtaptalk1341538453219.jpgthis is the front by the washer fluid resivor, I trimed about 2" there.
uploadfromtaptalk1341538675635.jpgthis is the back, its right aside the shock top bolt.
Sent from my ADR6350 using Tapatalk 2
SC88
SC88
Chicago Burbs
View attachment 16745this is the front by the washer fluid resivor, I trimed about 2" there.
View attachment 16746this is the back, its right aside the shock top bolt.
Thank for the info! The front seems to be where I am rubbing or was after the body work it seems they may have tweaked something and it didn't rub at all when pulling into the drive way.
Never had a issue with the rear but might when lowered.
billyinslo
