My V8 running on a 6 cylindar distributor?!?!?!
Misty
Big Lake, Alaska
So, I have had my Hoe for a little over a year now. It had alot of issues since then but I keep putting the money into it 1. because I love this Chevy 2. because I would rather put 300/mo INTO the truck instead of paying to keep it.
So far it has costed me around that.
I have had to replace all the basics, O2 sensors, ball joints, u joints, cv axle, idler n pitman arm, berings, and a few others (pardon the spelling)
Just recently I had a prob driving home, truck would not come out of the misfire, pulled over and it wouldnt even idle. Found the prob to be a bad lifter and bent pushrod. Replaced all that and in doing so had to remove the distributor and forgot to mark it so had to go through the whole process of timing it.
In the attempts to set the distributor the way a V8 should be set the truck would not even start. After messing with it for what seems like forever I come to find that instead of a "8" on the top it is in fact a "6".
Im like, "wtf" so I decide to set it the way a 6cylinder should be set and vola' it started! Ran fine for about a week. I am about to buy a new distributor (the correct one) and install it. I am hoping this will give me my power back and maybe power I never knew I had since I been driving it on a 6cy dist for so long. Not sure why I posted, I just thought it was kinda wierd deal but then Im new to the whole mechanic world so Im not sure. Any comment and/or suggestions are much appreciated. :emotions122:
chauncey0337
MLT, WA
Welcome and Wow, first time I've heard of something like this. Is this even possible. Anyhow, good luck.
M
Misty
Big Lake, Alaska
I wouldnt think so but the Hoe is running! Ran great for about a week then started to slowley lose power and now its lacking power and back into limp mode and driving like it was before just without the misfire. Going to replace the dist this weekend with the correct one and chase some wires to try and get my fuel gauge to work.
Oh, and thank you!!! :)
BattelWagun
Chi-Town USA
If you were running on a 6 cyl. dizzy then you would be missing 2 spark plug wires... And it most likely would never even start. Have you tries turning the distributor a little each way while someone's cracking her over to see if there is any improvement?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
you got pics of that mess and where are two of your non attached spark plug wire going. Technically the cap is the only difference between v6-v8 rotor distributor and sensor are same parts.
retorq
Kingman AZ
You sure about that?? I think the module is difference ...
And how exactly do you set a V6 distributor differently then a V8?? They should be set exactly the same, line rotor up with #1 plug tower when engine is at #1 TDC ...
SunlitComet
OBS Jedi-Do Good
I will look again when get back home again but a parts search say cap is the only different part on whole assembly. Even motor was same. Will check again later.
Sent from Sprint HTC EVO 4G via Tapatalk.
drackill1
