petethepug
Michael
Oh yea, what he said. The 6.2L does kinda give a certain feeling. Can’t put my finger on it
I have two 2024 Tahoes. 1 with 5.3 the other a 6.2. They are identical otherwise. Both z71, airride.
1. Towing - air ride is a must. Don't think you don't need it. It helps in every possible way.
2. If towing 6.2 or Diesel. Honestly around town the 6.2 just costs more because you have to run 93 octane. Otherwise there isn't a huge difference, but there is when towing. I am picking up my 2025 Tahoe z71 later today. I ordered it with the 5.3 due to the reason I just stated. I have a 3500 Sierra I use when I tow, so in my case I didn't need the 6.2. If i could have ordered the diesel I would have, as I like diesel engines.
I understand what you are saying. The OP asked specifically about options of a vehicle with the future towing of a travel trailer in mind. If I was buying a new Tahoe with towing in mind I wouldn’t want one without air ride, same as I wouldn’t want want without max tow and trailer brake switch.Air ride is a good thing to have but to say it’s a must is a bit of an exaggeration. A properly setup WDH can get rid of the majority of the squat. My XL tows our Sundance 24BH like it’s not even there up here in the mountains of Idaho.
Can you tow without these things, of course. Is it easier to already have them from the factory, yes.
Same with air ride. I would argue there is no comparison in comfort and stability when towing with air ride vs non- air ride. You can do it and not saying your setup doesn’t work well. I just feel if I was checking boxes to tow I would want that box checked. My experience is if the vehicle is already level when setting up the WDH it puts far less stress on components than if your trying to use the WDH to raise the rear suspension to level it.
It’s really oil soaked?Any oil soaked wet belt in any engine, regardless of where is it in the engine, or what its driving , is just a bad idea. Its the cheap way to get it done, not the best way.
