My Z71 seems lower than it should
Big Mama
Virginia
Hard to tell but if the dealer says they’re stock we’ll roll with that. Your picture of the truck just looked a little lower in front but they may have gone the cheaper route. Which is good for you.
Awesome, looks better already and helps with the confidence going forward. This may have been asked. Are you sure they didn’t use drop spindles up front? @iamdub is there any easy way to identify drop spindles if you don’t have both?
All you can really do by viewing from the back side with the wheels on is look at the position of the hub. It should be about centered between the ball joints but a little more toward the upper ball joint. On a lowering spindle, the hub will be 2" higher/closer to the upper ball joint. This puts that upper bolt hole in line with the upper ball joint and, on McGaughy spindles, it is eliminated and a screw-in stud is used.
Backside of OEM spindle, note how that top bolt hole is well under the upper ball joint boss:
Backside of drop spindle, note how that top bolt hole is much closer to the upper ball joint boss:
@Big Mama @iamdub Here are some pictures I took of the front, hopefully they are clear enough.
Definitely stock spindles. On a 4WD, since the hub location is moved upwards 2", the outer joint of the CV axle hits the stud and nut of the upper ball joint. The stud has to be trimmed and/or ground down flush with the nut. Sometimes the nut has to be ground down as well or a thinner nut is used. This is probably just with some aftermarket upper ball joints that have longer studs for whatever reason.
Dustin Jackson
Dustin Jackson
@iamdub Thanks for the confirmation sir, I will proceed with the peace of mind that I should find no surprises when I tackle the front this weekend.
Speaking of front, unless you want or need to stock up on tools, you can borrow specialty tools for free from the major auto parts stores. No need to buy coil and strut spring compressors for one job when you can borrow them from free on an as-needed basis.
I borrowed two sets of strut coil compressors, one from two different stores, because one set on these struts is too weak.
Dustin Jackson
Dustin Jackson
That is good advice, I see that the front springs are much thicker and stiffer than the rear so I'll be sure to use two sets of spring compressors. In your experience can the upper insulator boot be reused? It hadn't occurred to me that I might need to replace it until yesterday but shipping times are killer right now.
Mine had about 199K miles on those parts and I reused them. My boots have small holes worn into them and I wish I had gotten new ones, but I already had it apart and had to get it back together so I reused them. I may be taking the struts back apart for some minor tweaks later on so I'll get new boots before I do that.
Dustin Jackson
Dustin Jackson
@iamdub @Big Mama @PNW VietVet Gentlemen I did it. I appreciate the assurance that I can do it myself and this weekend I finished up the front and now I am done and saved $1,200 in installation! Here is how the Tahoe sits with Bilstein 5100s set to factory height with MOOG 81244 springs in the front and MOOG 81069 springs in the rear.
