Mystery problem and cool pics of high mileage
Baylee Brown
Baylee Brown
Update: replaced the TP sensor since the reading was a little off. I still have the same problem.
Baylee Brown
Baylee Brown
IMG_1534.JPG (Pic is old) Replaced the ignition coil and the module that goes with it. Replaced the idle valve on the throttle body. Cleaned the map sensor and put a new air filter on too.
So I took off the distributor cap and rotor button to make sure everything was on correctly and it was. But when I was trying to put the cap back on I dropped a tool and it went to the top of the transmission. So I had to crawl under and fill around. While I was down someone pointed out that an exhaust pipe flange was missing.
joakleyTYF
