1999hoe
aka HOVERHOE
So i finally figured out my trucks p0300 code issue ..
Parts changed
coolant temp sensor
Gnition control module
fuel pressure regulator
cam position sensor
new spark plugs
new plug wires
new dist. cap
new rotor
new spider injector assembly
turns out after i changed cap rotor and wires it was still running like.shit maybe even a tad worse so i figured the injector assembly was the culprit and didnt mind changin it since it also.contained the new fuel pressure regulator so my mechanic blew the holes and gas spit out of cylinder 5 so.good call on changing.that after it was installed it fired quick no.backfirws or anything (previously backfired so hard and broke the starter housing on my brand new starter )but still couldnt figure out why the code was there and why its still misfiring well when.i replaced the cap i bought what i.was told was the.best cap rotor they had which was made by accel well after everythig else my mech says lets change the cap.again so this time i grabbed the ac delco version and presto chango misfire gone after all the aches and.pains it was the ******** cap which was the first thing i changed
Parts changed
coolant temp sensor
cam position sensor
new spark plugs
new plug wires
new dist. cap
new rotor
