Posi12Bolt
SOB thats clever!
yeah one i sent you pics of i need to remove the bags to do the free travel mod. That being said endlinks/shock extenders helped ride but the tbss air bag set up rode better and sat lower at ride height. If he doesnt like the way it rides now then going to see if he wants to try the trailblazer ss bag set up.
have to say you were RIGHT ON. After the travel modification, shock extenders, and adjustable sway bar, the back suspension was still too stiff for me to drive everyday. Installed the TBSS bags just like you said. They are a direct bolt-on to the 2007 Yukon, ride SOOOOOO much better AND I get 1-1/4" lower.
The only other thing I was suspect on was towing my 3,000lb wakeboard boat. First test was empty truck with empty boat, 80 miles. It was actually smoother with the boat. Second test was 440 Miles, FULLY loaded truck AND boat on a camping trip. Same as before, smooth ride, no glitches or leaks. All I can say is thanks! Oh, and sorry for not believing you right away!
you did the swap also??? Never knew
yep. Swapped up to the 2500hd big boy swap. [emoji39]
