nbs 4wd air ride?
00yukon
ok so i recently picked up a 2002 tahoe 4wd from work and was wondering if its possible to slam this beast on the ground.
i know usually 4wd and air ride dont mix but is it possible to remove the front axles and lay out?
if this would work does anyone know a place that makes bag kits for the front?
the rear would be no problem the front is my only issue.
Alex33
It's possible, just expensive. I know there is a Denali on the site that has AWD and lays sidesteps. His username used to be Trick28, i think it's changed recently tho.
Donnie Yukonie
Yates Caretaker
You are correct his name now is young28
Sent from my DROID4 using Tapatalk 2
Young28
The Yukon God
ga
anything is possible. No kits are really made to lay these out.
As far as control arms and such im sure you can get with ekmw or Michigan metal works.
Knobz
Santa Cruz, CA
Extensive MetalWorkz outta Texas, they have it down when it comes to slamming and bagging anything. I think they make a control arm kit for a slammed/bagged setup on our trucks.
BurbyRST
