NBS Tahoes/Suburbans - which aftermarket diff covers fit?
Z'06
Houston, TX
The two biggest constraints to make one fit are obviously the panhard bar (fixed location) and the sway bar (fixed location, unless you have a Hellwig adjustable sway bar).
Thanks.
Z
Z'06
Houston, TX
Bumping this. Is anyone running an aftermarket diff pan on a NBS Tahoe/Suburban?
Z
Z'06
Houston, TX
What would be the ultimate goal? More capacity?
More capacity for cooling, plus switching to cooler-temperature aluminum. I'm wanting to upgrade to a Truetrac, but it's a no-no to use synthetic gear oil with it. Synthetic runs cooler, so more capacity, combined with aluminum, should be more than enough to offset the heat increase from running non-synthetic.
Tremendousslouch
