Nbs with 20's tire pressure
Yukongk
NY
Just curious what tire pressure you guys are running at.....this is only for NBS vehicles with 275/55r20 size tires (NNBS stock 20" size). I've been running around 37 psi but I want a better ride when going over small bumps as it's a bit harsh. I tried 35psi but I thought it was too low as I was screeching a bit around corners. I'm also considering trying to fit a larger diameter tire for more sidewall.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
No matter the specific size, I try to stay around 38lbs cold, 42lbs hot
OHSIXX
Milwaukee
Running my new Nitto 421Q's at 42 cold. They ride the best there. My old Goodyear LS-2's were at 35 cold.
dhulsey779
Phila
I also run my between 35-38PSI. Once I ran it at 40PSI but that seemed to harsh on the bumps.
YukonXL04
The Riverboat
Arlington, TX
On all of my tires they usually stay around 35-38 cold. When I had my sierra If I was loading it up heavy I would bump it up to 60, but horrible ride without weight in it. 3/4 ton with 80psi max.
Yukongk
Yukongk
NY
Don't the NNBS's tire placard on the door jamb call for 32-33psi with 20's? I'm going to air down and see how they ride.
Sven-from-sweden
