nearly stalling after sitting for a couple days
SunlitComet
OBS Jedi-Do Good
unknown at this time.
that seems a bit low on wot. i would test your pressure regulator with a hand vacuum pump to see if it is the issue before replacing the pump.
---------- Post added at 11:53 AM ---------- Previous post was at 11:53 AM ----------
tho ironically those number seem right when running ethanol.
---------- Post added at 12:10 PM ---------- Previous post was at 11:53 AM ----------
you know what before going any further give me the vin character for your engine. either v, t, u or z and it will be the eighth digit from the beginning.
ccapehartusarmyINF.(ret)
Gilbert AZ
its always the fuel pump, when i was checking to see if GM has a recall on my vehicle i found an old recall on GM fuel pumps just about 80 percent of this forum including me has had to change out the fuel pump
Y
yup
I replaced the fuel filter and cleaned the MAF sensor and that seemed to fix it.
SunlitComet
OBS Jedi-Do Good
if that included a filter recently then either injectors are acting up or the pump is not strong enough. do you have a test procedure for the entire fuel system? i might have one around here.
2014 Tahoe LTZ
