Need advice for wheels/tires on 2dr 2wd
R
RSTahoe99
Rowlett, TX
I went with 20 x 8s, I would suggest going for the 20s as tire/wheels combos are getting more and more inexpensive. I like the staggered look too, but after having 7 inch in the front and 10 in the back on my 17s it gets to be a PITA when you cant rotate the tire and get even wear. Eventually you will be buying tires in pairs instead of sets.
lildavid
hows it going. im new to the website, but i recently lowered my 98 2 door 2wd. i failed to measure the height prior to lowering it but im guessing its a 6/4. djm flip kit and hangers in the rear and 2" dropped spindles and i installed a 1/2 ton truck coild in the front which i cut one complete turn . i have a slight rake in the rear. i managed to fit on some 22"x 9.5" foose legends all the way around. i had to widebody the front fenders about one inch and roll the lip after if carved into my tire on the test drive. in the rear< i also had to roll the pinchweld located in the wheel well.
carbed87
i have 20's with a 275/45/20 tire on my 2wd tahoe. cheap tires, proportional look, and still pretty practical
techrider
