Need Advise: Wanting to buy quality Halo's
CM Burns
Alabama
I've decided to spruce up the front end of the Denali, and look at some either smoked, or black Halo headlights & bumper lights. There are companies like Spec-D which make a few nice pair, so I guess I am addressing anyone here who has quality halo's and have no issues with them. There a lot of knock-off brands on Ebay for about half-price, but I want to spend between 200-300 for a quality pair, I will be keeping this truck until it dies on me one day.
The wiring seams pretty simple whether you splice the LED/Halo rings into the parking light wires or some people will run a completely seperate switch so you can run them during the day/whenever you want. Thanks, and sorry for the long post.
Aaron_L
Arlington, TX
Most of those lights are not great. If you decide to put HID's in them they are really bad. If you want a set of lights that work really well, then I would suggest a retrofit. You could add halos to them, or other effects as well, and they would function a lot better. There are companies that do retrofits that are pretty expensive, or if you want you could do it yourself for way less. When I did mine I added halos, but I don't use them as much as I did when I installed them.
CM Burns
CM Burns
Alabama
Thanks guys, I talked to a few people today and mentioned it, and they pretty much said the same thing, that they are garbage at a good price, and that I would get sick of the Halo, and also a Denali isn't supposed to look like an import with the glowing Halo's.
Much thanks!
ezdaar
Chat Troll
Redneck central, Aka Houston
then, get the, retro the kit i linked into them, the halos will be removed when you retro them.
Then they are Very nice headlights. just go really easy on the adjusters.
YukonXL04
The Riverboat
Arlington, TX
Eh. I had those exact headights... they sucked all around. **** fitment, crappy projector, and dim halos...
Better off doing a retrofit on some stockers
707jimenez
