Need help Bazooka tubes or Box
sebby55
sebby55
Brooklyn NY
I made up my mind (sort of)
Kicker TCVT122 (10TCVT122)Compact Single 12" 2 ohm Comp VT
Has anyone used this box before?how is the bass?also i read that you should use a amp 75-90% of the subwoofer rms. I also read that you should use a amp with more rms (ex.100rms sub/150rms amp)which is the correct info?
01yukonslt
need more deebeeeez!
Spokane, WA
you always want the amp to have the same if not more power than the sub can handle in order to send it a good clean signal. it doesnt necessarily hurt the sub to run it at less power but many mistake the gain knob for a volume knob and will send a clipped signal to the sub resulting in failure. if you have a 300 watt sub and 300 watt amp you should be ok though. not sure on the ratings on that cvt but in a sealed enclosure you can run a little bit more power without hurting anything.
sebby55
sebby55
Brooklyn NY
Thank u everyone for the input on this topic.I feel pretty comfortable on picking out some more music now.
DIY_DAD
So Cal
bazooka's arent worth the $ they are very poor quality subwoofers with low powered amp, you can get pre fab boxes loaded with subs and sometimes even an amp for dirt cheap nowadays, check http://www.crutchfield.com they always got scorchin deals and are extremely reputable, i get all my stuff from them <5 stars>
piperdunc
