Need help diagnosing "Service Air Bag"
msgbent
Hey dkad260, I've somewhat similar intermittent Service Airbag fault on 2016 Tahoe. It seems only to occur when making right turns. Had you noticed similar or any correlation on your vehicle?
Hey all, Any suggestions as what might be causing fault condition and what to check? In case relevant, I bought used last year but GM site lists it as having had airbag recall completed in 2017.
Thanks.
D
dkad260
That does seem to point to the clock spring, I'm assuming the 2016 uses one.
If you have a MDI you could monitor the resistance of each loop when turning the wheel to verify.
Since I unplugged and reseated everything, my codes haven't returned. However my Service Airbag light would illuminate at startup most times so no turning of the wheel was needed.
HTH.
Bradford333
