Need help lifting my 2001 Chevrolet Tahoe
ATIII
Brighton, CO (Denver)
So I've taken in what y'all have said and I've decided to go with a body lift, keys, spacers, and bilsteins. I just need help now finding what y'all recommend?
Here is what you need...
Front shocks: Bilstein (24-186643) 5100 Series Shock Absorber https://www.amazon.com/dp/B00BYNJAVW/ref=cm_sw_r_awd_m-R-ub1HW0M01
Rear shocks: Bilstein (24-185783) 5100 Series Shock Absorber https://www.amazon.com/dp/B009FU66FO/ref=cm_sw_r_awd_baS-ub104YG2C
Coils: Moog 81069 Suspension Coil Spring https://www.amazon.com/dp/B00498ZR7A/ref=cm_sw_r_awd_YaS-ub1K4D3TH
Keys: 1" - 3" Torsion Bar Lift Keys Chevy Half Ton 6 Lug 4x4 Trucks https://www.amazon.com/dp/B00BEN1PXI/ref=cm_sw_r_awd_QbS-ub103YDWK
Spacers: 1.5" Lift Rear Axle Coil Spring Spacers Tahoe Yukon Suburban https://www.amazon.com/dp/B00BEN3BEY/ref=cm_sw_r_awd_LcS-ub0YPNVHA
As far as your BL, I have no experience or recommendations for that.
I saw the set you posted with the keys & 2" spacers, will the 2" spacer still work with the Bilstein 24-185783, instead of the 1.5" ones you listed? I love the look of your rig, exactly what I'm looking for. Want mine to sit higher than the other 50 million hoe's out there, but it still needs to be family friendly.
liftedtahoe
arkansas
my hoe
Here is my tahoe! I have
3" lift keys (only cranked about 2")
Shock extenders
1.5" spring spacers out back
3" body lift
Factory escalade 17s wrapped in 35/12.50/17 mud grapplers
owl_93
Yeah those bilsteins should work for anywhere between 1-3" of lift. I'm contemplating getting some 2" spacers myself since the z71 coils have broken in a little I want to bring the ass up another .5" if I could.
diverstan
