Need help lowering my 2004 GMC Yukon XL Denali
01ssreda4
I did a djm 2/3 and started with stock keys. They were done at about 2 inches of drop, the problem is there was no adjustment left for the alignment guy. I never did install the drop keys because I ended up getting some drop spindles instead. Get the shock relocation brackets for 60 bucks and it will ride like stock. My autoride is deleted btw.
TheAutumnWind
my 04 had spinldes, keys, and a camber kit to achieve a 5" drop which means I had the keys backed out to about 3" of drop. I don't think you can get that out of the stock keys
So you just use no jounce stop in the front and/or have very little uptravel?
Zigger21
Zigger21
North Dakota
Zigger21
Zigger21
North Dakota
Yeah... does your autoride function properly?
It works properly but the warning is stuck on "i
It works properly but the warning is stuck on " Service Auto Ride". I replaced the compressor and went underneath and applied air to the shocks and they pump up all the way and didn't have any leak at all that heard and they stayed pumped up for 5 minutes on each one without a whisp. But That dumb warning wont go away.
Chip18
Dayton NV
I'm very sorry for being a rookie and all but what does "Jounce" mean?
It's a situation you want to "avoid" the rear axle bangs off the rear bump stop. Shocks and springs work together by absorbing the upward energy from bumps, if you hit a bump and you don't have enough suspension travel in the rear ... the process gets halted and the energy gets "transferred to the frame" through the unaltered bump stop location to the vehicle.
In the "Real World ..." that means "instant unanticipated" change of direction! My most spectacular example was back in the day with a full "Koni" Fiero!
80 mph sweeper with a mid corner bump ... I knew it was there (the bump) because, I'd hit it many times in my Merkur XR4Ti (Stock) at 100 or so. So 80 in the "modded" Fiero ... no big deal?? Yeah not so much it was late at night in Ca ... all the "nut balls" prowl the canyons late at night.
I hit that bump hard and the rear end lifts up and I'm in the other lane??? Still pointed in the intended direction since I never lifted but my eyes got pretty big!
But think "Unlimited Hydrofoil" and the boats skipping off the waves ... your "Vehicle" will do the same thing if you don't have enough rear suspension travel!
In San Jose Ca we have a popular stretch of road with some really bumps! And it often takes out high dollar, modded cars with full coilover suspensions! Super stiff springs and limited suspension travel ... the unknowing hit those bumps on full kill and they don't make it to the bottom of the hill!!
Happens all the time out there. Most stock cars with full suspension travel were actually faster down that hill than the full kill turbo charged, coilover equipped monsters!!
I actually shattered a headlight one night going up there in my "Modded Mini Truck" Toyota. A Mustang though ... he was going to pass me up the hill??? Yeah ... I don't think so!! Good Times Good Times ...
But yeah as I am want to say ... I give sound advice ... I don't often follow it so ... don't drive like that on "public roads!" :)
Pretty sure "Norcal SS" can tell you how much clearance you need to have with your vehicle at rest. :)
erich07yukon
