need help upgrading stock mids and highs
BeingSoberSuckz
StuckIn,LA
I was wondering what would be some good speakers to replace my stocks with..Im pretty sure there components, but I really dont wanna spend 2 or 300 dollars, so what are some good coaxils I can use, and also some good tweeters to replace the old ones with..also, Ill be upgrading my subwoofer setup, and i was wondering if ill even be able to hear the speakers on the roof in the rear, or should i just not even worry about them...also, can someone show me some good horn tweeters....
budget=3-400 dollars...or less if possible
THANKZ
B
BeingSoberSuckz
StuckIn,LA
welcome to the site, here ya go, do a component set up fornt, and if you add a sub in the back, forget the rear speakers back in the hatch. Do doors, and good speakers up front.
$109
http://www.sonicelectronix.com/item_11516_Kicker+KS650.2.html
or the RS, which are smoother, silk dome tweet, $399
http://www.sonicelectronix.com/item_19435_Kicker+RS652+-RS65.2-.html
hey, preciate that...will the tweeters replace the stock ones in the same location, or will i have to mount them elsewhere?
N how bout some good horns? Id like to put a few of them in there, could you point me in the direction of some good horn tweeters.
THANKS AGAIN
blueflamed03
Oklahoma
Yes, those can replace the factory location, and depending on where you mount them, you won't need the horns :)
Thad Chauvin
