Need help with lifting the front higher than rear!!!
Ddarby1
I recently bought a 2000 yukon 4x4 that already has a RCX 6" lift, and aftermarket keys. When I first got it the front sat about 1 1/2" lower than the back. I cranked the keys all the way and still barely got the front to sit even with the back.
I'm really wanting to go with the bulldog look. I want it about a inch or 2 higher than the front. Other people I've talked to that have a 6" lift and aftermarket keys have the exact look that I'm going for. Is something wrong with the suspension? Or is there a way to get more lift in the front? I might even possibly be open to dropping the back about an inch, but I've never had a truck without leaf springs so I'm not exactly sure how to go about doing that. I would appreciate any help y'all could give me.
Thanks!
D
Ddarby1
I have aftermarket torsion keys. They are maxed out and still doesn't sit higher in the front.
Z-56 Hoe
What do I do????
Houston
Lift spindles the 3.5" ones and the keys not cranked just installed and a 2" rear spacer!
SBK RACER
Just curious, Why would you want the front higher than the rear?
Is it for serious off road performance?
ericjvasil69
