Need help
Joe718
I have 2002 Escalade
I was driving fine cut the truck off starting it back up all good then out of Nowhere my cluster started acting up I get no temperature no transmission temperature no fuel reading security light flashing battery lights flashing suspicion control is flashing anyone out they can help me figure out what’s wrong with this
OR VietVet
Multnomah Falls
Military
Willamette Valley
Check your battery cables and ground cables for good connections first.
The standard answer when the ghosts start giving you fits. When Steven says check them he means not just tight. Needs to be clean and corrosion free and also check for corrosion inside the battery cables insulation. Lots of ground wires to locate and inspect. Good luck and welcome to the forum.
wjburken
Eastern Iowa
Welcome to the forum.
Listen to what Steven and Ron have suggested. These vehicles get really wonky with bad grounds and low voltage.
While you are doing the checks that have been suggested, with both battery cables off disconnected from the battery, cycle your head light switch a couple times and pump the brake pedal a couple times to bleed off any stray voltage in your system.
Joe718
Joe718
Do any one know where are all the grounds are on a 2002 Escalade
OR VietVet
Multnomah Falls
Military
Willamette Valley
CharlieD139
