Need inside rear cargo measurements
chadman
Hi,
I am wondering if someone can take their tape measure and 4 measurements for me.
I am looking to buy a 2009 chev tahoe, but I am trying to find out if there is enough room for my power wheelchair to fit in the back with the 3rd row seats removed.
I need to know these measurements:
1. rear height opening.
2. length along floor from the back door(closed) to the back of the 2nd row seat.
3. length from back door(closed) ,about window height, to the back headrest of the 2nd row seat.
4. width along floor
It may be a little work, but I would appreciate your effort.
Thanks
Chad.
bberck
Hi,
1. rear height opening. = 35 inches
2. length along floor from the back door(closed) to the back of the 2nd row seat. = 44 inches
3. length from back door(closed) ,about window height, to the back headrest of the 2nd row seat. = 40 inches
4. width along floor = 49 inches
Thanks
Chad.
There you go
Acero
Chevy tahoe will surely be great to fit in a wheelchair. The car is not that spacious even if you will remove the third back seat row. But, I think it is just enough so that the wheelchair won't slide from side to side on bumpy roads.
online
emann_01
my guess is English is not his primary language....
zach2011
Platinum Member
I understand that, I can see why you or anyone for that matter wouldn't like them for that reason...whenever I install mine I do check to make sure they're not like those insanely bright ones that I see a lot around here. I don't know if those come from little eBay sellers or "high-quality" manufacturers, but I think DDM does a good job because they are a little brighter than stock but not blinding in my opinion.
I wish GM would have put Sierra/Silverado bulbs in ours because they are beyond bright enough at stock.
And well, I understood everything but that last sentence. Probably meant something along the lines of "My son is definitely in a wheelchair", or similar. Either way I'm glad Chad stepped in and gave the measurements!
RepublicanRebel
