You may check out the fte resonators.
Sent from my SM-N960U using Tapatalk
...Actually, I'm gonna see if they have a ~21"-22" version with center inlet and outlet. That'd give me about 40" of my current muffler...
I'm interested in seeing how that patriot insert changes the sound.AP XS2579 muffler and Patriot H3844 insert ordered!
Now to check my inventory for 3" pipe...
There's a guy on YouTube that compared it to a straight pipe and tested air flow. Wasn't much difference.I'm not so sure I'm gonna use it. I get that it's basically like adding in a baffled muffler, but it may be too restrictive. I've even considered trimming the spirals in some spots to give it some straight flow, but that might make it ineffective. Trimming it might also induce turbulence more so than just redirecting the exhaust flow, and doing more harm than good.
I like to test things where possible and my current thoughts on it are to stick it in a length of scrap 3" exhaust tubing, chop off my exhaust tip, and stick the scrap tubing over that to make some before and after comparison vids. I won't be able to test power gains or losses, just sound. Well, I might could monitor the MAF and MAP sensors to see if there's any distinguishable differences. That'd give me some sort of idea of power changes.
Yep that's the oneI think I found the vid you were referencing:
For this resonator:
Only 10 CFM loss at over 1,100 CFM. I don't know how relevant it is to the Patriot insert since the Patriot has a step after each 360° turn whereas the FLO-PRO is a continuous helix. Also, the FLO-PRO in the video is a 4" and my Patriot is 3", but that's still well over the needs of a 5.3.
There aren't many reviews on it and most were Diesel guys. Watching that vid led me down a wormhole of Diesel vids with and without the resonator. Apparently, while very effective at killing drone on a straight-piped Diesel, it's also restrictive on high-powered Diesels. That is completely irrelevant to us since they're much larger displacement engines that are turbo'ed.
Scaling it back to our world:
CFM = Cubic Inches x RPM x Volumetric Efficiency ÷ 3456
323 x 6000 x .85 ÷ 3456
1,938,000 x .85 = 1,647,300
1,647,300 ÷ 3456 = 476.65
So, figuring with an overestimated VE of 85%, our 5.3s are moving 476 CFM at redline. From what I've seen so far, that 3" Patriot insert shouldn't hurt the flow much at all at this level of CFM but should still have a noticeable effect on the sound.
...Testing it "on paper" is fun and all but I'm still gonna try to "real world" test it. I like comparison vids with minimal variables.
