Need major help
Can anyone help wit my Tahoe... recently changed fuel pump, fuel filter, plugs, coils, and wires, an
  • My thoughts are cut cats
    Votes: 0 0.0%
  • Second choice knock sensors
    Votes: 1 100.0%
  • Total voters
ChrisC100
Can anyone help wit my Tahoe... recently changed fuel pump, fuel filter, plugs, coils, and wires, and all 4 o2 sensors. Truck now runs like shit and keep throwing lean codes and random misfire.. also blowing black smoke and soot out exhaust... cats are still on.. attached files are codes
08grey
Pull a plug and get a good look at the tip
Sent from my SM-G930VL using Tapatalk
C
ChrisC100
IMG_1781.JPG Still having same problems truck running like shit and dies at stop light. Changed intake gaskets and both knock sensors along with pcv and MAP sensor... someone help just had cats removed. Also truck runs fine wen fuel systems are open(OL) and wen it closes(CL) it start to run badIMG_1783.JPG IMG_1784.JPG IMG_1782.JPG
All of this started immediately after you replaced all of those parts? Why did you replace them? Did it have a problem before? If it started right after replacing them then obviously one of them is bad. I'm inclined to blame an O2 sensor (one of the upstream ones, not after the cat) since it happens in closed loop and it's affecting the fueling. Check your wire connections first.
*Edit
Just noticed all the O2 readings are 0 volts. Did you replace them with the wrong kind(s)?
Capeles
