need new passenger side mirror
drowndindreams
Unknown
short story is as i was pulling out of the gas station some f'ing douchebag in a huge truck clipped my mirror. i put the truck in park and got out and the bastard ran. *************. the plastic's fine but the mirror is cracked. where would I buy it, and do I need to replace the whole assembly or just the mirror? thanks guys
crmzendrgone
M town Arizona
I think you'll need to buy the whole assemble. I cracked mine on the driver side and got one at checker for about 60-70 bucks.
bsamoul
Hoe Enthusiast
Walnut Creek, CA
I'm pretty sure you can angle the glass down and pull it out. I've done it before on mine, but I'm not entirely sure it's supposed to do that! Plus I've seen just the glass on ebay, so I'm pretty sure you can just do that.
nimrodcs
Joplin, Missouri
99_2door
omaha
It'll probably work. Just as long as you don't use those ****** adhesive pads they give you.
Use a high strength epoxy resin. Works real good. :)
the problem i've had so far with the others i've tried is that they fit like shit. i haven't even got far enough to see if the adhesive holds!
Big Hoss
Mine smacked a sign and broke it I bought a new one for about 30$ on Ebay. Looks the same but I didn't want to pay extra to have someone else install the entire thing so I put the mirror on the assembly piece that sticks out from my vehicle because I couldn't get it off on the inside. Fits alright ain't had no problems. My windshield is getting replaced next.
I found the mirror face for about 12 bucks in the Advance Auto tonight. Looks like just a press fit on, but I'm debating on what kind of adhesive to try. Maybe Super Glue will be a sufficient hold?
On another note, the damn AC has gone out again. It was well over a hundred again today, too. Think I've found the leak, from a hose or fitting above the compressor.
CoyotesRUS
