Need picture of interior roof with headliner removed
moosehead
moosehead
Do you have factory DVD in the roof?
txgmc
Yes I do.
---------- Post added at 07:11 AM ---------- Previous post was at 07:09 AM ----------
This was my problem
I have not figured out where exactly it came from but I do know its not rattling around up there any more! I was able to put my hand up in the sunroof opening and fished around until I got a hold of it.
big_b_in_PA
Billy Badass
Central Pa.
That is your rear gutter, it attaches to the rear of the sunroof carriage assembly. It also is what pushes your sunroof cover back when you open the sunroof. To put it back in place, you're going to have to take the glass out of the roof, and mount it on to the carriage again. I had to drill a hole in each side of mine, screw it in place, and silicone the screw heads. It has held up for the past 3 years with no problems. You definitely want to put this back in place again, as it diverts the water to the drain holes on either side. If not replaced, you're going to end up with a wet seat.
emfadz
