Need some help from the cold weather guys!
chip
chip
Tampa
Ive installed new batteries and had to replace them within a few months. It could have a bad cell, or just starting to go out. Head over to your autostore and get a battery test done. Only way to find out for sure
You know, you make an excellent point! I did check the water in mine.........and it WAS low. I topped it off, thinking I should be fine, but again, you do make a great point. I should have the charging system checked.
Thanks!
mmeachem
+1!!! I have the truck for 2.5 yrs North jersey gets to be solid 20's in jan never heard of this
What part of jersey..??
I live in jersey city on the other side of the holland tunnel
Yeah maybe the battery they tend to act up in the cold
GeneralNoobzor
Phoenix, AZ
I had the issue, was driving home and gave me "Reduced engine power" pulled over. Turned off. Tried starting after 10 minutes. All was good. I erased the Throttle Position Code. Haven't had a problem since. This happened to me last winter. Been over a year. It's not a big deal.
chip
chip
Tampa
Very good to know! Thank you.
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
I work in auto parts (for now). The battery going bad is very common when weather changes in the late fall and late spring. I'd get that and the alternator checked first. As for the throttle position problem, when was the last time you cleaned the plate in the throttle body? Weather change can make the crap that usually accumulates in the inside more sticky or less pliable, thus causing a problem.
Sent from my myTouch_4G_Slide using Tapatalk
chip
chip
Tampa
Great advice! Thank you.
dcogswell
Intake gaskets, the original ones tend to cause leaks in cold weather. There are some better ones out there that resist deformation during cold weather. There about 80 bucks retail.
When you're in there, replace your knock sensors, wiring harness & oil pressure sending unit.
And if you haven't already, do the seafoam treatment x3, (intake, fuel & oil). There are plenty of write-ups out there about this.
All of the above will help you with cold weather problems.
chip
chip
Tampa
Thank you Sir (I have Seafoamed).
Gzes
the drifting 2dr
Wichita tx
not to thread jack but what is the benefit of seafoam besides pissing off the neighbors?
Tssonebay
