Need some wiring info
Cornelius
Charleston, SC
My brake lights are out. High mount light works, tails/rev/turns all work
The fuse "veh stop" keeps blowing
Replaced brake switch
My test light lights up with the brake pedal at the power side "veh stop" fuse but that fuse keeps blowing
Confirmed continuity from circuit board at right rear to tails so I believe there is a short to ground between fuse block and circuit board.
Seems like a short to ground somewhere between fuse block and tails but can't find it without knowing which wire to isolate.
Can anyone help me out with a good diagram of this? Been searching all day! Thanks in advance
Fless
Super Moderator
Elev 5,280
YW. Might help to add a bit of vehicle info to your signature so we are certain about what you're driving. I'm assuming '00-'06 due to the thread being posted in that section.
SinStar999
