Need support. Just found out my radiator is leaking
DodDel5-3-6L80e
Good idea on the water pump. Now would be the perfect opportunity. I was surprised how easy this water pump is to install vs other makes. The 5.3l is super mechanic friendly- thank you Chevrolet.
iboughtatahoe23
iboughtatahoe23
So Is watching a video for a 2014-2018 Silverado gonna work cause I can’t find a decent video that isn’t an hour long for my year Tahoe
iboughtatahoe23
iboughtatahoe23
I hear that’s a little more difficult than the radiator because you have to torque down the bolts to a certain spec and there’s a certain pattern they go on I was told? And use paper gasket
watch it be the head gasket lol #totaled
as far as options on radiators as long as it has a transmission cooling option the oil cooling option does not matter the lines would just not be used. so you can use it with or without oil cooling.
water pump I wouldn't even blink a eye at unless it has over 160k on it, then it's a matter if it is leaking or not. when they go out they tend to start leaking from the bearing seal which you will only see from the bottom with a flashlight and tilt mirror. Otherwise when they fail they do so in dramatic fashion like blowing out the gasket. seeing one with worn out fins (internal) is pretty rare unless you have been running straight water for a long period of time with corrosion eating away at it.
iboughtatahoe23
iboughtatahoe23
I got 178k on my odometer. No clue if it has been changed before. Doubt it
Soooo pressure test and some UV dye?
naah, just look harder with a flashlight, take that splash guard off and look up.
and/or drive it and then park it over some cardboard, let it sit for a good while/overnight and then look up from the wet spot on the cardboard.
Babadook76
