New Air Lines for Rear Shocks
bersh
U.P. Michigan
Anyone know the part # or where to order a new passenger side air line for my 2007 Yukon XL? All the shocks were shot (94k on it) and I finally got around to ordering shocks from Arnott. I almost went for the bypass kit, but decided to go with the passive rear instead. When I tried to remove the air line from the shock, it would not budge. I tried squirting it with PB Blaster and let it soak, but no luck. I tried to pry and pull and twist as gently as I could, but the line broke off near the shock. Once the shock was removed, upon inspection the air port is so corroded that the line is rusted in and I don't think it was going to come out no matter what I did. No that all the new shocks are in, the ride is nice, but I need to order a new line. It looks like the factory line is part of the wiring harness that handles the electronic dampening as well. I don't need the entire thing (unless I have to order it that was). A number of searches on the typical GM parts sites don't seem to show any of the air compressor lines, so I'm obviously looking in the wrong spot.
Any advice or input appreciated. I would be willing to go with a generic or aftermarket line if need be, just want it to work and to put the fuse back in so the error message goes away.
Thanks.
B
bersh
U.P. Michigan
If anyone is curious, the part number I got from Arnott for a new passenger side air line is 88987900. This is meant for the older 2001-06 body style, but supposedly it will work for any vehicle up to 2014.
patniven
