New here, with a leaky roof
99tower
First post here, I find so much help on forums this seemed like the place to start.
Just got a 99 Burb, 4x4. 7.4L
Truck is in pretty good shape, been going thru the small stuff like tires, pitman and idler arms, shocks, and a general deep clean. The interior was filthy, but is coming along nicely.
My first problem that I MUST address is a leaking roof! At least I think it is the roof. The edges of the headliner are wet and drip, water also drips from the rearmost right seat belt that is dangling.
I have the factory roof rack with 6 or 8 feet, two screws each. The plastic on the edges of the feet are pulled away a little.
Is this a common problem? I looked for gaskets for the feet, with no luck. Also read the nuts on these screws sometimes come loose inside the roof, preventing removal.
My thought is to use a real good clear sealer to plug the screw recesses, and surround the feet.
Any thoughts or advise from the forum?
Thanks in advance, Frank
Tahoe14
Central Fl
Welcome and some one may comment that had a 99 in the past. I think you would have better luck in the 99 section as this is the 2015+ section, good luck.
99tower
Thanks, let me find my way over there.
BMPGBH
