- Joined
- Aug 2, 2018
- Posts
- 7,586
- Reaction score
- 10,437
Welcome!
Welcome! I would suggest changing all the fluids and then using the severe service schedule due to the weather there. Do a fluid exchange for the transmission and change the rear differential fluid. The coolant is good for 5 years or 150K miles, whichever happens first. I reckon it's due.
Get your hands on a bi-directional scan tool like the Tech-2.
What are the specs for these fans/motors?
much Higher CFM fans plus an auxiliary oil and transmission cooler fanWelcome! I would suggest changing all the fluids and then using the severe service schedule due to the weather there. Do a fluid exchange for the transmission and change the rear differential fluid. The coolant is good for 5 years or 150K miles, whichever happens first. I reckon it's due.
First I've heard of this. Got any specs for the fans?
standard hummer equipment or also known as (k5l hd cooling package), my Denali came with the external cooler, yanked it and put in the trucool 40k, switched my fans/shroud to the k5l (700w), added the B&W bigger trans pan20935856 Radiator
TAHOE, YUKON; 5.3L; ALL; W/ HEAVY DUTY COOLING (it's a bit beefer then the standard or trailer cooling package)
$595.00 $387.70
fan HD option
https://www.gmpartsdirect.com/auto-...as-engine/cooling-system-cat/cooling-fan-****
Power Steering Oil Cooler
Part Number: 25918689
Transmission Cooler
Part Number: 19244188 or 20880895
after market external Oil cooler with fan
differential cooler to top it off
you add your own AUX fans to those items for MAX cooling...
