New spark plugs, new wires, but GAS SMELL,
Scope75
Check the firing order and make sure you didn't mix up any wires.
---------- Post added at 08:34 AM ---------- Previous post was at 08:33 AM ----------
Also did you compare your old plug to the new ones to make sure the tip was the same length. If they are shorter they might not be far enough into the combustion chamber.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
If you tune up is correct then you may be dumping to much fuel in there thru the injection assembly. I take it this started exactly when the tune up was done?
bowtiefreak
No Quarter
Near Philly
dumb question, are the fuel lines ok? It may be a non-tune up related problem. I have driven myself crazy chasing issues that weren't really there. I always eliminate the obvious first.
Lonestar67
