New starter & still wont start
Big Poppa74
My 97 Tahoe wouldnt start & there was 1 loud click when I tried turning it over. I replaced the starter solenoid, thinking that would be it..... I'm wrong. Anyone have a good idea for my next step? I tried jumping it thinking it may be the alternator....... wrong again.
quietfly
have the actual starter tested, sometimes they also go bad. autozone will test them for free
Dpsthomas
If the battery is good, check all the connections (battery terminals, starter cables, etc) then the fuses.
bowtiefreak
No Quarter
Near Philly
did you replace the whole starter or just the solenoid? Tap it with a hammer and see if that works...seriously
SunlitComet
OBS Jedi-Do Good
unknown at this time.
:worthy: to the hammer.
---------- Post added at 09:57 PM ---------- Previous post was at 09:56 PM ----------
BTW my oem starter had a label on it to not use hammer.
gpracer1
Phoenix
Hit it too hard and you can break the magnets, then it really wont work.
The key is to tap the starter while someone is holding the key in the crank position, for those who dont know.
Could also try putting in neutral and starting to see if it is being inhibited.
SunlitComet
OBS Jedi-Do Good
After having to do it once that justifies replacement for me.
By the way was that click a relay or solenoid. Is it not possible that the motor side contacts or commutator are burned out.
msu50000
