NardDog
- Joined
- Mar 26, 2017
- Posts
- 125
- Reaction score
- 117
So today is the first real day of driving the burb after a whole new Dorman suspension kit (uca,lca, sway bar ELs, sway bar bushings, idler arm, pitman arm, tie rods, ends) was installed and belt tech drop spindles AND and an alignment .
The shop said they put a wrench on just about every bolt and even took the tie rod ends off to be sure the spindles were not too tight. They told me I really needed a new gear box since the steering was not returning back to straight after a turn. i never noticed it before but now its obvious with a whole nee front end.
During the first real drive around town everything seemed ok. I could tell the burb was sloppy in the turns. On my last errand i pulled into a parking spot and as im in the turn I hear it. A quick small croak or creak whichever.
As IM driving I start to hear it on every turn, and I can sit in park and with the play in the wheel turn right or left to make the truck creak and croak.
I will be getting underneath this week sometime to try and locate the noise but until then maybe some of you have an Idea of where the noise could be coming from.
